TomPerverteau
Did some more stuff on it at home today.
Put the body inserts in.
The bridge landed here. It looks like just a tad further back than I intended. That's OK, it has lots of adjustment for intonation. Even more important is the side-to-side location for string alignment. According to the lines I drew, it's right on the money. It's pretty parallel to the pickup route, too.
The early Floyds had the C-shape knife edges on both sides. I spaced the distance between the studs here like on an early one. There is almost 0 clearance between the saddle and the head of the stud with this bridge! It kind of freaked me out at first. I double checked on the treble side (the side with the C shape), and it's right where it should be. But damn, that's a close fit!
Test-fitting some of the mahogany filler blocks I made. Remember, this will be Bondo-ed up & painted, so they only have to be a rough fit. This will also get final milling for cosmetics after it's all filled in. I used mahogany for consistency with the rest of the body, thinking about the sound.
Filler blocks glued, clamped, and left to dry. There is still more filling to do after this to get everything looking even & correct around the bridge.
The de-butchering is moving along!
