Cagey
Mythical Status
Super Turbo Deluxe Custom said:My finish skills are horrible, so maybe someone could chime in if this is a good idea or not, but if you sprayed a layer of clear on top of the white, would that make that line cleaner?
The way to get a clean line is to mask it off and shoot a layer of clear to seal the edges of the tape, then shoot your color. Remove the mask and start layering clear with level sanding steps between coats.
Or, just cut it for real binding and install that. You'll still have to do more clear coats, but you'll have a defined line.
Before you start layering the clear on is a good time to put a custom headstock decal on if you want to bury it in the finish for a professional-looking result that will wear much better.
