Thanks, Rick.
The pickguard pattern is now adjusted. It seems when you rout linoleum, it trashes your router bit. It wore a very shallow groove in mine so when I used that bit to make the new routing pattern for the pickguard, it ended up with a slight high spot all the way around it. I had to set the bit a little lower and cut with another part of the blades to work that down. Fortunately, that bit was a cheapo and not one of my good Whiteside flush cut bits. I guess I'll have to find another material to use for test pick guards.
