I'm glad you asked that. I hadn't weighed it at all. I was going to do that after the bulk of the wood has been removed BUT, since you asked I just ran down there with a bathroom scale to get a rough idea (the bath scale is only calibrated to the nearest half a pound). It came in at 4-1/2 lbs. Bear in mind there will be a 7/16" roundover, and belly and forearm contours. I also have toyed with the idea of a rear relief for upper fret access on the lower horn and a contoured heel. If I do all of that, it should be significantly lighter. I'll weigh it with a postal scale after it's all routed and shaped.Bagman67 said:I'm curious: As that blank approaches its final dimensions, how's the weight?
Hell yes! That color works wonderfully!Rgand said:After much head-scratching, I've decided to go for transparent red on this one. That grain needs the right color.
