xParallax
Hey all, here's my build log for my Roasted Swamp Ash Tele Deluxe!
Gonna call it 'Artisan' after the Fender range it was initially based on but I couldn't afford!
It's probably surpassed that now and the 'F' word is probably an insult to it!
Body:
Model: Tele Deluxe
Orientation: Right handed
Scale: 25-1/2"
Wood: Roasted Swamp Ash
Rout: Top Rout
Pickup Rout: Standard Pickup Routing
Bridge: Vintage 6-Hole Tremolo
Jack Rout: 7/8" (22mm) Side Jack Hole
Neck Pocket: Strat® Shape
Contours: Tummy Cut
F-Holes: None
Binding: White Binding
Top Finish: Clear
Back Finish: Clear
Finish Type: Gloss Finish
Neck:
Style: Stratocaster®
Construction: Modern Construction
Scale: 25-1/2"
Orientation: Right Handed
Neck Wood: Maple
Fingerboard Wood: Indian Rosewood
Nut Width: 1-11/16"
Back Shape: Standard thin
Fret Size: GD6150 (Gold Color)
Tuner Ream: Schaller (25/64")
Radius: 10-16" Compound
Fret #: 22
Inlays: White Pearloid Blocks
Side Dots: Black Side Dots
Binding: White
String Nut: GraphTech White TUSQ XL - Standard Nut
Finish: Clear Gloss
Peghead Veneer: Roasted Swamp Ash to match body
Pickguard:
Shape: Tele® Deluxe
Color: White Pearl
Neck Pickup: Gibson Humbucker
Bridge Pickup: Gibson Humbucker
Control 1: Volume
Control 2: Volume 2
Control 3: Tone
Control 4: Tone 2
Upper Switch: Toggle Hole
Neck Pocket: Strat® Neck Pocket
Equipment:
Bridge: Gotoh 6 Screw Vintage Tremolo in Gold
Tuners: Fender 'F' Staggered Locking Tuners in Gold
Pickups: IronGear Rolling Mill (Neck), IronGear Rolling Mill Overwound (Bridge) in Gold Covered
Controls: 2x CTS 500 ohm Push-Pull Pot (Tone Control both Pickups w/Coil Split)
2x CTS 500ohm Standard Pot (Volume Control both Pickups)
1x Allparts 3-way Toggle Switch in Gold
1x Allparts Output Jack in Gold
2x 0.022uF Orange Drop Capacitors
Knobs: Barrel Knob with White Pearloid Inlay in Gold
Strap Locks: Fender Infinity Locks in Gold
Trying my hand at Soldering, first time I've ever soldered a guitar up start to finish
Pic 1: Body out of the box - Absolutely stunning!
Pic 2: Neck out of the box - Perfection!
Pic 3: Copper Shielding Tape throughout entire cavity - Don't know if this will be beneficial but I might as well give it a go!
WD: Seymour Duncan wiring diagram I followed for 2 Vol, 2 Tone, 1 Switch, Coil Split Push Pull on Tones.
Pic 4: Solid Start (Had to redraw the diagram because IronGear pickups use different colour wires for almost all of their wires!)
Pic 5: Getting there! Slowly getting better at soldering as it goes, and it shows!
Pic 6: Testing the soldering job out! (Worked first time with all functions)
Pic 7: Phew all that wiring fits back in the body cavities!
Thanks for reading, I'll update soon with more progress!
Rhys
Body:
Model: Tele Deluxe
Scale: 25-1/2"
Rout: Top Rout
Contours: Tummy Cut
F-Holes: None
Top Finish: Clear
Back Finish: Clear
Neck:
Scale: 25-1/2"
Neck Wood: Maple
Nut Width: 1-11/16"
Fret #: 22
Binding: White
Finish: Clear Gloss
Pickguard:
Shape: Tele® Deluxe
Color: White Pearl
Control 1: Volume
Control 2: Volume 2
Control 3: Tone
Control 4: Tone 2
Equipment:
Rhys
