I meant sand back lightly leaving the the grain xtra highlighted with the black.I probably will, I like a yellow but I'm trying to get the wife's buy-in and she says black
If you want all the pickup combos you could do a five way switch plus a “neck on” toggle that would use a push-pull or mini toggle to add neck pickup signal to any position of the 5 way switch.I already have the neck and bridge pickups, do not have a Charlie christian pickup. Am thinking about the wiring harness and thinking I can get a 3 pickup harness with 5 way switch and hook the neck pickup to the middle then I can use it as a tele, neck/ neck and bridge/ bridge (while I only have 2 pickup) and when I can buy a cc then use the whole harness.
Thinking future , when i do get a cc , hook it up to the neck position on the 5way . This would give me the following;
Bridge/ bridge and neck/ neck/ neck and middle/ middle.
Why? Because I want the charlie christian to be used alone and have a regular tele, I would not have middle and bridge or all3 pickups. Or doing all that I mentioned with a 7way . Am I wrong?
When I zoom in, look like 4.7 or .47 and I am pretty sure it is cts 250k solid shaftWhat cap is on the tone pot?
