rgand
Epic Member
Got the PG pattern done except for needing to make an adjustment. Where the control plate pattern joins it, there wasn't enough room for one of the mounting screws.
That meant making a whole new control plate pattern. Fortunately I had an old Roadhouse pattern lying around so I modified that. Other than needing to adjust the location of the control holes, it worked out fine.
A pencil through the holes shows they need to move a bit. The pencil line on the body shows where the plate will be.
Test fit with the neck. All looks good.
The next step will be to locate the bridge plate and then cut the PG pattern around that.
