It's a little of many aspects I have liked on guitars. The pickguard was actually inspired from a Maverick. As far as ergonomics go, I haven't tried it with a neck on it yet. Now I'll have to do that. It should feel like the Telerauder with less mass.Rick said:Your designs are really good, in this one l see the musiclander, a breadwinner, a jaguar, a telecaster, a teledeluxe and a wgd. Looks ergonomic.
This is a very good point. I just put it where Fender did on the Swinger. That doesn't mean it is the only place to put it and certainly not a set thing at this time. I also question how good that will be. The only drawback I see to putting it on the centerline is that the strap must go behind or over the rear upper horn. Behind would push the top outwards and over would shove it back against your side. I will probably have to try both or maybe a bit above center to see what is best before painting then plug the unwanted hole(s). I have a bunch of holes to plug so a couple more is nothing in the scheme of things.Rick said:I was thinking about how it would balance with a strap and I’m curious about why you chose the the bottom button to be placed higher up than on the center line? I’ve seen that on carvings, or keisels. I believe the breadwinner has it on the center line. That is king to be a fine looking git.
I have a friend with a strat that color. Gorgeous guitar.Rgand said:A 1949 Studebaker Champion:
I can believe that.BlueTalon said:I have a friend with a strat that color. Gorgeous guitar.Rgand said:A 1949 Studebaker Champion:
