C
Cowbell Fever!
Very nice! Looks beautiful.
Cowbell Fever! said:which bridge do you have? I believe the Gibson "Nashville" has more travel than a standard tune o matic
I cant tell from the picture, but I have seen some guitars with tuneomatic saddles turned back wards for further adjustment also.
Cowbell Fever! said:Not a math wizard, but that looks like it has a bit more travel.
ragamuffin said:I'm not sure how I did this and I thought I double/triple checked when locating the bridge, but it looks like I place it about a half an inch too far forward. Looks like the Hipshot might just barely work but I'm not 100% sure
Sadie-f said:Meantime, accept she's not properly intonated, and enjoy playing that beauty.
stratamania said:Sadie-f said:Meantime, accept she's not properly intonated, and enjoy playing that beauty.
If it is that far out it would be obviously out of tune so how can someone enjoy playing it?
Sadie-f said:Ouch, maybe this isn't so much a problem as an opportunity to fix something in the machine shop?
What's the bridge? Can you add photos showing the bridge from pov of the bottom, maybe a couple of angles?
stratamania said:After all that finish work...I almost hate to say this but you may need to consider this body a learning experience for the next one.
ragamuffin said:Sadie-f said:Ouch, maybe this isn't so much a problem as an opportunity to fix something in the machine shop?
Hey Sadie the current bridge is a TonePros TP6A, a pretty standard Nashville style. What would you suggest doing in a machine shop?
teleme01 said:sounds simple but couldnt you peg the holes and drill new ones? like you would do with small pickguard holes ?
ragamuffin said:stratamania said:After all that finish work...I almost hate to say this but you may need to consider this body a learning experience for the next one.
I get what you're, but I'd rather hack/route things up a bit than have this body just sitting around unplayable
