line6man
Epic Member
Cagey said:line6man said:I was thinking about experimenting with passive filters, but I'm too lazy to try to calculate frequencies from a complex impedance source, when I don't even know what frequencies need to be fixed half the time to begin with. I guess the best way to do that is to put a breadboard on top of the guitar and play around with L C and R components until the guitar sounds good. :blob7:
You don't need to go through all that rigmarole. A 250K or 500K pot in series with a .022uf cap to ground is all the filter you need, and it's adjustable. That's what 99% of all guitar filters are, give or take a bit on the cap size.
Rigmarole?
Obviously I'm going to have a tone control. I don't use it much on bass, but I use it a lot on guitar. Actually, I think the only reason I use the neck and middle position on my Strat, is because it kicks in the second tone control parallel to both pickups, so I can leave it rolled way down and go between bright neck pickup and dark neck pickup at the flick of a switch.
