Rewriting the whole post because ... the original I think would confuse my position.
We only sprayed water this evening. I tried both the external mix "airbrush" and the detail spray gun. I think the pattern put out by the brush is likely big enough to do a good job on a guitar sized object. With the detail gun, it's gonna be about four passes per side.  The main limitation I think will likely be the cup size. The brush came with a tiny 1oz jar and a 3oz jar. Well.. the 3oz jar is a "mixing jar" and doesn't come with a siphon lid. You can't spray from it.  I think there'd be less overspray with the brush - the gun puts out a LOT.
I mixed up about 4oz of 2lb cut garnet. I've seen folks say you can spray 2lb, but most general advice says to shoot 1lb cut. I'm planning to shoot 1lb cut, but I wanted some 2lb for a wipe test tomorrow to see about color in the pores. I'm currently thinking shoot the whole thing garnet, maybe even dye it darker, then sand it back so it's just in the pores. I don't want it India ink black in there, just add some depth. Then grain fill (clear) and shoot blonde shellac over that.
I hope to get something on wood tomorrow. It's shellac. I often joke about metalworking - "It's just metal - you can always melt it down and start over." Shellac is a little like that. Only a few things don't go over it, you can pretty much blend coats any time you want to throw more alcohol at it. It's almost hard to screw up. Almost. I'm sure I'll manage somehow.  About the only thing you can't do is completely remove it from the pores.
