BigSteve22
Crazy? More like BRILLIANT! :icon_scratch:
BigSteve22 said:Crazy? More like BRILLIANT! :icon_scratch:
swarfrat said:I kind of like the honeycombing. I'm not a big fan of clear pickguard over the wiring guts but if it were still neat - clear over honeycombed body would be kinda cool.
But wait, there's more!! :laughing11: Also drilled out 2 bores in the neck pocket, and 4 where the trem block lies. Very wormy, big worms! :laughing7:swarfrat said:If you got 8oz from just that ...
swarfrat said:If you got 8oz from just that ... maybe I should think about it on this Plutonium Telecaster body that just arrived on my doorstep. (Northern ash. The heavy stuff. Beautiful body. But you could hurt somebody with it.). I'm wondering if I can train some termites to hollow it out or something.
I'll be very interested to hear how your test wiring goes. I see that the middle pup is RWRP, but the dummy winding direction does not switch when it's active. Might that not increase noise by feeding an inverse signal into an inverter? I believe that will reinforce rather than cancel, no? Also, what op-amp are you planning on using?fuzznut said:I'm gonna first try out the noise cancel circuit on a s-s-s strat, simpler wiring and I already installed the nc pickup in it. It'll be a test bed, most likely the circuit need tweaking.
BigSteve22 said:I'll be very interested to hear how your test wiring goes. I see that the middle pup is RWRP, but the dummy winding direction does not switch when it's active. Might that not increase noise by feeding an inverse signal into an inverter? I believe that will reinforce rather than cancel, no?
:icon_thumright:I played with a dummy coil on my JZ, without much sucess. Ended up buying an EHX Hum-Debugger pedal, which works wonderfully. I wish you all the best with this, keep us posted! :headbang:
swarfrat said:i designed but didnt build a circuit that was just the ticket. Dummy coil buffered and inverted. Each pickup had a balance pot you blend from -1.5 hum to +1.5 hum, which drove the ground of each pickup. you had enough gain to work with, and since the hum signal is low impedance it doesnt impact the LCR of the passive single coil it feeds.
Now that sounds promising! Anxiously awaiting your progress reports! :icon_thumright:fuzznut said:I breadboarded it last winter and it killed the hum 99.9%.
