Xplorervoodoo
I know I'm kinda late, but if I can find a tape measure, I can take some dimension measurements of my Voodoo Explorer...
If that'll help any? :dontknow:
R n R Dr said:I think it's just a question of how everything is getting scaled.
R n R Dr said:You have a picture? I'm curious what it looks like!
R n R Dr said:JDB: the problem is that the neck pocket is only 2 or 3 inches wide, and we trying to match up bodies that are 25 - 27" diag. A small error at 2-3" gets blown up at 25-27", so the comparison might not be that accurate. But I see what you're saying.
R n R Dr said:JBD- Did you use a Gibson Explorer body? Or the Explorer Pro? Look likes an Explorer as that one would be/should be bigger than the Warmoth ... based on Warmoth saying their's is based on the smaller Pro body. ==>> OK: you used 27" which would be the Explorer. The Pro is 25".
R n R Dr said:But the angles all appear to be very close if not dead on too, which is good. (Well ... *except* for the inside of the upper right bolt.)
R n R Dr said:I *keep* trying to decide whether it's worth it to get Warmoth's and try to shape it to the correct (or ... close enough!) size, or just have them do a custom Gibson Pro body ... But then somehow I'd need to get them a trace of the Pro.
This is very useful. I appreciate it very much !! :headbang1:
R n R Dr said:The Pro picture at MF and other places is an edge on view because, neck to the right, you can see the bottom edge of the guitar.
R n R Dr said:They are a fair amount different.
R n R Dr said:I guess maybe it really depends on if a person is after the spirit of the Explorer, and Warmoth certainly does OK there, but if a person is looking for a straight copy, that ain't gonna happen. Warmoth can do custom shapes, but they cost more too...
And to the casual observer, they are identical. I think you could mod the Warmoth to be a closer likeness of the Gibson, but you would have to be very careful. I think you could bring it close enough to where it would be almost impossible to tell the difference without a Gibson nearby to compare it to.
SrDeMaFp said:When I do my explorer build I'm gonna order the body from another site (their copy has more exacting dimensions) and order my neck from Warmoth.
