TBurst Std
To the OP, stop guessing and simply email sporthitech and tell them what tuner hole size you have. They’ll tell you the correct one if they have ones that fit. 5 days of discussion for a 5 second email.
Yes, easy enough to find out by email. I can't recall whether others have already said this, but the 10mm Hipshot size fits into Warmoth tuner holes of 25/64". I've done this on several Warmoth necks, including one that was sprayed with their clear gloss finish. Even with any overspray into the holes, the tuners still fit with no extra work needed. Worst case scenario would be a few minutes with sandpaper wrapped around a dowel or pencil, it would be very easy to enlarge by a tiny amount if needed.To the OP, stop guessing and simply email sporthitech and tell them what tuner hole size you have. They’ll tell you the correct one if they have ones that fit. 5 days of discussion for a 5 second email.
Did you put the washer on the back? If not, what did leaving it off the front accomplish? Is this an aesthetic preference?I know this should be illegal and the parts caster police should lock me up but this is how my staggered tuners are set up View attachment 63452
Also, and I'm sure this is what you meant, @stratamania , but to clarify the UMP thickness effectively brings the tuner post down by about another 1mm, further increasing break angle over the nut.
I heard a warrant has been issuedI know this should be illegal and the parts caster police should lock me up but this is how my staggered tuners are set up
It gives me better access to the string hole, I didn't realize that the 1mm ump was the reason why there is less access. Esthetic is not good but unnoticeable, I will probably put the washer on eventually.Did you put the washer on the back? If not, what did leaving it off the front accomplish? Is this an aesthetic preference?
i'm buying a new neck with new tuners. i just need the correct dimestions for the tuner hole. seems like all manufactures say "fits 100mm OR 13/24" everything is a "10mm or". warmoth only does standard sized holes (inches") so i don't have holes. i need them drilled to match the tuners i buy.Yes, easy enough to find out by email. I can't recall whether others have already said this, but the 10mm Hipshot size fits into Warmoth tuner holes of 25/64". I've done this on several Warmoth necks, including one that was sprayed with their clear gloss finish. Even with any overspray into the holes, the tuners still fit with no extra work needed. Worst case scenario would be a few minutes with sandpaper wrapped around a dowel or pencil, it would be very easy to enlarge by a tiny amount if needed.
I can deal with the tuner hole size later. i'll probably just buy and then measure for myselfWelcome to the guitar world of imperial and metric measurement conversions and rounding.
The tuning peg itself is smaller than the part that is around a modern tuner and goes through the hole. A Schaller has a size of 10mm, and Hipshots and modern Fender types all need a comparable size tuner bore in the headstock. That means with Warmoth the closest is to use 25/64" which is 9.92mm.
You may need to use a reamer or sandpaper wrapped around a dowel or pencil to adjust the holes when fitting, especially if there is any finish that may have got into the holes.
If a manufacturer's dimensions are exact in one system such as 20mm or 0.787" or an unusual fraction, which system do you think they are using?
With Warmoth they use 25/64" which a 9.92mm for a tuner hole size, do you think they use imperial or metric drill bits?
Tuner bore, and shaft dimensions use the diameter of the hole.
Hipshot have not put it on the diagram as they have already mentioned what size post holes 10mm or for vintage 8.5mm each set of tuners is for.
TLDR - Modern tuners, tuner bore size usually 10mm - Fender / Schaller / Hipshot /Sperzel
Vintage tuners - 11/32" or 8.5mm dependent on manufacturer.
Tuner Hole Options
warmoth.com
YES!!! so tell me why Warmoth doesn't have an 8.5mm or a 10mm tuning hole option?? those would be spot on and would take the guessing game out of it. don't give me a standard 13/24" "equivalent" hole.......it's clearly NOT equivalent. so why not just use a REAL 10mm or 8.5mm drill bit???Seems the most common tuners are vintage 8.5mm and 10mm
seems to me that 13/32 would be the best fit without having to modify the tuner holes and leaves you .01253" of "play" inside the tuner hole.I also find inaccurate metric conversion super frustrating. Ideally it would be better to maintain 0.001” precision.
However 25/64” is close enough for 10mm tuners. I actually desire a snug fit for the tuner machine so a little bit of sanding seems normal to me. 13/32” is a sloppy fit, so in my world that is an “EPIC fail”.
Yep, I've had Hipshot tuners on a bunch of necks with 25/64" and never had any issue; they fit fine no issue installing or with use.I also find inaccurate metric conversion super frustrating. Ideally it would be better to maintain 0.001” precision.
I've never had to modify/ream out the holes on the 25/64seems to me that 13/32 would be the best fit without having to modify the tuner holes and leaves you .01253" of "play" inside the tuner hole.
you came in a bit late to the thread so here is the short jist.I've never had to modify/ream out the holes on the 13/32
@stratamania got hipshots but he decided to go with a compound hole that was "schaller 25/64" - 11/32". But from what i read, 25/64th was not a regular option at the time. from his well documented pics it appears that the front is 25/64" and the back end its 11/32" so some part of the tuner peg base is smaller on the backs-side and larger on the front side...........it's just really hard to see the shape of the tuners my my eyes, altough you can see in a closeup of the holes that they were more open on the front and smaller towards the read.............
and then i answered my own question regarding the size of the tuning pegs, because his box is marked 18/19/20mm. so i guess i'll order those tuners an then measure with a micrometer to see the exact dimension.
yeah, i'm super guilty of "over-thinking" things.1. Yes, 18/19/20mm is, in my opinion, slightly better than 19/20/21mm heights. All else being equal, why not have a tiny bit more break angle? Having said that, I doubt this 1mm difference will matter either way, and if I were buying then this difference, in and of itself, would be irrelevant to my purchase decision.
2. Warmoth's 25/64" hole will accommodate most or all tuners advertised as 10mm. I think you're taking the measurements too literally, inferring more precision than is intended, and worrying too much over this. When a manufacturer says 10mm, do we believe that to be 10.000mm, 10.00mm, 10.0mm, or 10mm? I assume the latter, meaning I won't be surprised with anything outside a range of +/- .1 mm. I also don't know how precisely you can count on Warmoth's 25/64" holes measuring up in your hands. I don't doubt the bit on the CNC has that exact dimension, but is there no sanding done afterward, does wood not expand and contract as it changes from their environment to yours, etc? The worst-case scenario, if you order with 25/64" for 10mm tuners, is that you'd need to enlarge the holes by a very, very small amount. A few minutes with a piece of sandpaper wrapped around a pencil and you're done.
As Aaron has mentioned in more than one video, they can't make their parts fit every manufacturer's products perfectly. There are too many options out there, and they change over time, too. Putting together a partscaster often involves some fitting work. The only way to guarantee things fit well is to buy a complete guitar. I honestly don't think you'll have any problem fitting any of the tuners you're looking at into the holes Warmoth drills for modern (as opposed to vintage) tuners, namely the 25/64".
so i re-read your post on the blue guitar and was fascinated by all of it....especially the finishing of the unfinished guitar neck. it looks absolutely amazing!At the time of that thread from about eleven years ago, that stepped tuner bore was required for Schaller tuners and was the best fit that Warmoth offered for the Hipshots I was using.
Since that time, Schaller tuners have a different design and now use a straight hole which also works fine with the Hipshots.
As Warmoth do not offer an actual 10mm bore the best option is 25/64".
That is also an option; however, most people prefer a snug fit for tuners and not have play. With the 25/64" if needed it can be reamed or sanded to give a good snug fit.
Excellent.
