TBurst Std
even if the tuners would go out of tune with just one touch of the tremolo bar. That's the "temperament" of the guitar.
I use the 10-16 compound unless a certain bridge, like the gotoh wraptail, needs something specific like 14".
There isbliterally no drawback to the compound, so why not use it?
Any reputable tech should have no issue with compound radius. It would be obvious too. Ends sticking up, or middles sticking up. And I would guess stability would be all over the place. Got my Jackson refretted by Aperio. Never played better!In theory there is a possible “drawback” If there is a possibility of a future re fret. There may be errors of it not actually being an actual 10-16 compound radius again since it’s more difficult to re fret accurately. But it may not really be really noticeable and your fretboard will probably still be ok especially if you get used to it the new subtle changes…..If may bother some people if they want precision
Well, logic says that if you seat the frets all the way tight to the board, you will have no problems in that regard.In theory there is a possible “drawback” If there is a possibility of a future re fret. There may be errors of it not actually being an actual 10-16 compound radius again since it’s more difficult to re fret accurately. But it may not really be really noticeable and your fretboard will probably still be ok especially if you get used to it the new subtle changes…..If may bother some people if they want precision
Hey thanks, that's a really good technique. I'll try it today.To help with heavy hands, try playing without your palm or thumb touching the neck. Don’t worry about speed, vibrato or anything else.
What you will learn is the amount of finger pressure required to sound the note correctly.
Once you get that feel, now bring in the thumb and palm which allows you use even less finger pressure.
It offers you a gauge to establish what’s needed. And it’s less than you think.
No well, I mean, when you hit that whammy bar hard is going to go out of tune, even if you know how to work that tremolo system.That’s just a bad set up. A I cac make any 6 point trem with non locking thunders stay reasonably in tune. It’s a 1 beer job. You can do it yourself. Get book
Heavy handed. You need to lose that like a skirt. I used to be. Got over it by having an instrument that would not tolerate it.
Nothing anywhere says the strings touch the fretboard on a fretted instrument. In fact you’re not suppose to, that’s why there are frets. If you’re playing a cello, that’s different.
my friend, you want a floyd. I can dive bomb that sucker into satan's wine cellar without issuewhen you hit that whammy bar hard is going to go out of tune, even if you know how to work that tremolo system.
It’s not the trem itself usually causing tuning bugs, it’s the nut, saddles, break angles at those locations, and tuner gear lash. If these are out of wack, a Floyd can cure it in the same way that sawing off your arm can remove a splinter.No well, I mean, when you hit that whammy bar hard is going to go out of tune, even if you know how to work that tremolo system.
naw, it's more like replacing a really weak arm (like a baby's arm or perhaps a small cat's) with a burly muscle arm (like from a character in a Chuck Tingle book).Floyd can cure it in the same way that sawing off your arm can remove a splinter.
Yeah, this is true. At least in my experience. And maybe it's the science of it. The trem only dives, what causes trouble it's the other components. In my case atm I think it's mostly the nut. I can hear it lately. Time for more lubricant or replace it. One step at a time.It’s not the trem itself usually causing tuning bugs, it’s the nut, saddles, break angles at those locations, and tuner gear lash. If these are out of wack, a Floyd can cure it in the same way that sawing off your arm can remove a splinter.
Look at what Frudua can do with a 6-screw, or what Mike Puisheen does with a Jazzmaster. The only unit I think is unfixable is the Gibson side pull… that’s just an art deco piece designed to cure neck dive in SGs.
Nah a dive bomb it's fine. Shake it like a Polaroid picture.my friend, you want a floyd. I can dive bomb that sucker into satan's wine cellar without issue
Yes, but with all the other components dialed in you’re really only fighting strings that aren’t stretched / fatiguingC'mon guys. Even Floyd's go out of tune.
Close but not quite. 12-16" is common among Charvel, Charvel by Jackson, Jackson, Grover Jackson and every other variant of the two I can't think of. Own a few modern builds - all 12-16 - and been looking at a lot of 80s/90s Charvel/Jackson recently in my indecision of "should I build a 7/8 Warmoth or just buy a fusion/super dinky?" EDIT : Or keep praying that one of the times I email a reverb seller about a Carvin DC they actually have a 24.75.Isn’t a 10-16 radius with a Standard Thin essentially what Charvel does on most of their guitars?
^This x10 (or more)But the experiences of others on their preferences is not really going to help you. I would suggest you play many guitars to get a feel and zone in on the specs that work for you
That would be awesome. Carvins have such poor resale for such well crafted instruments… good value if you can find one that fits the bill.Or keep praying that one of the times I email a reverb seller about a Carvin DC they actually have a 24.75.
