Super Turbo Deluxe Custom
Epic Member
Body:
-Flame Maple laminate on Mahogany
-double MM pickup route
-Ivoroid top binding
-blue dye top, transparent blue back
-truss rod trench route, no neck removal for adjustments
-5 way blade switch route
-7/8" output side jack
Neck:
-Wenge/Jet Black Ebony
-no face dots, side dots only
-white corian nut
-3/8" tuner ream
-Fender right hand reverse headstock
-6130 nickel frets
Electronics:
-Carvin passive 4 conductor humbucking MM style pickups
-5 way switch
N parallel
N+B outer coils parallel
N+B full humbucking
N+B inner coils parallel (may change to bridge series humbucking)
B parallel
-500k CTS pots
-.022 mf orange drop cap
-shielded cavities
-my own design grounding bus to eliminate soldering to backs of pots
Hardware:
-DangerousR6 neckplate
-Hipshot string thru A type bridge (Fender AM Standard retrofit)
-Hipshot 3/8" Ultralites tuning machines
-Hipshot o-ring control knobs
-Hipshot 3 string retainer
-string thru ferrules
-Electrosocket Jack
-Schaller strap locks
I know this is for finished projects, but rather than start a 3 separate threads in Just out of the Box, Work in Progress, and Finished w/pics, I'd do one. This project won't drag. When finished, I'll update the title with "finished w/pics."
So, this was on my front porch yesterday:
It contained this:
So far, I've installed ferrules and strap buttons and applied the first coat of shielding paint to the control cavity. I did the soldering iron trick with the ferrules, but that would only take it so far. I've hammered them straight in before, but the previous ones were silver whereas these were black. Not wanting to scratch or dent the finish on the ferrules, I took a rack mount screw and used 2 plastic washers and a metal washer and tapped them in.
Cagey and I have been seeing eye to eye on a regular basis. To bring balance back to the universe, I'm shielding this bad boy.
We all know where this came frame.
Head shots:
Neck:
-white corian nut
-3/8" tuner ream
-6130 nickel frets
Electronics:
-5 way switch
N parallel
N+B full humbucking
B parallel
-500k CTS pots
-shielded cavities
Hardware:
-Electrosocket Jack
It contained this:
Head shots:
