stratamania
Mythical Status
Well done, should look good with the body. Have you played a scalloped neck before ?
stratamania said:Well done, should look good with the body. Have you played a scalloped neck before ?
Rgand said:That should look really good. Nice selection. Looking forward to seeing that.
vikingred said:stratamania said:Well done, should look good with the body. Have you played a scalloped neck before ?
Yes, I have. Me and Malmsteen used to hang out.ccasion14: And I have always wanted one. This makes guitar #12 in my collection.
stratamania said:vikingred said:stratamania said:Well done, should look good with the body. Have you played a scalloped neck before ?
Cool, I have two scalloped necks, including a Malmsteen Strat. My favourite strat is the Malmsteen.
ccasion14:
vikingred said:Received the body today. Simply. Incredible. Crazy.
double A said:FYI...and this has been kept somewhat hush, hush...you may want to check out some of the Vintage Tint necks from the last month or two. You might like the color better. :icon_thumright:
Axkoa said:I'm not sure why but Koa has really been growing on me recently.
stratamania said:Axkoa said:I'm not sure why but Koa has really been growing on me recently.
Sooner or later with a name like Axkoa it had to happen. But as it normally only grows in Hawaii, it could be a good thing it is growing somewhere else now :turtle:
Seriously, I wonder if it is possible to cultivate Koa and get it to grow somewhere else.
vikingred said:Cagey, where do I obtain & how do I install "threaded inserts"?? This is contoured neck pocket.
Axkoa said:Well I guess I just have to make a Koa Warmoth guitar.
I wouldn't be surprised if it were possible to grow Koa here in Australia. Probably in the northern parts of Queensland. Apparently Tasmanian Blackwood is a very similar type of wood to Koa, as well as climate in Australia being similarish to Hawaii.
Old Spud mentions stainless...........................Just a note on the inserts here: the ones that Cagey mentions above are brass (part no. 90016A009). They're fine, but brass is a soft metal, and many times I find that the tops strip off as the insert digs deeper into the wood. So, to counteract that, I've started using stainless steel inserts, to much better effect. You can find those at McMaster-Carr as well (part no. 95807A100)
