Cagey
Mythical Status
Emerson pro CTS pots turn slightly easier. If that's important, then spend the money, keeping in mind they also get turned easier from inadvertently brushing against them. Otherwise, there's nothing further to be gained.
Always use deep mount (long shaft) pots. You can put a second nut on them behind the mounting point to set outside thread exposure, while the short pots can't be made longer. That's why they include two nuts/washers with those pots.
Use 500K pots across the board. You can always modify later if necessary. I strongly suspect you won't find it to be necessary.
