davegardner0
OK time for an update
Since the neck is now glued on, the next order of business is to do the rest of the potentially "rough" jobs before finishing up the gloss on the finish.
I started with the pickup rings. I used calipers and masking tape to locate them side-to-side. Front to back there's really only 1 right position since the pickup rings aren't any bigger than the pickup rout holes.
Then I taped the rings to the body and used an inlay tracing scribe to mark the screw hole locations.
These pickup ring screws are #2 size, so I'll use a #1 drill bit size to drill the pilot holes. The tricky thing is that the body is carved AND the pickup rings sit at an angle on the body so that they're parallel to the strings. Solution: tilt the drill press!
I verified the tilt with the pickup ring actually on the guitar:
Then drilled! This was definitely a tense part of the build, I had it built up in my head beforehand as super scary but everything went well. The guitar did barely fit on the drill press (which I just got, for this job) so I'm glad I got a 12" model and not a 10".
Success!!
Success!!
