Les Paul from scratch
I prepared a piece of mahogany to fill the gap; a touch of Titebond and that's it. Tomorrow I'm going to sand it flush and install the fretboard (another scary task for a first-timer).
Damned routers are sometimes enough to piss off a saint. But, it looks like you're recovering nicely. Keep up the good work!
as the fretboard is radiused I've used a StewMac radiused block (wraped in plastic) to hold the fretboard when clamping. For the rest of the board, wood scraps with some foam underneath... an a lot of clamps to avoid gaps
the previous pic is not wrong: there's no dot on fret 2. In this pic, the dots are glued; I've used black superglue
The glue has dried, so I sanded flush. I must work a little more on it but the result it's OK. It's really hard to work on ebony. Next step: raw cut, sand the sides and start fretting (a deep breath and I go for it)
The peghead contour (in the Zemaitis shape) and the fretboard edges are traced. I've cutted tue upper side of the fretboard and sanded it flush so I can start installing the side dots in a safe way because the other side of the neck block is flat so it didn't turns or moves
To install the side dots I've drilled a hole in a piece of aluminium angle that I use as a template. This allows me to put all the dots at the same distance. This idea it's not mine, I borrowed from a guitar forum mate (I don't remember if it was in this one or in projectguitar but... Thanks a lot!!!)
