stratamania
Mythical Status
Best of luck with your pedal.I'm sure it will be fine. Not as good as mine mind you![]()
I'll have to try that with my design just to see what happens!Envelope Filter ... interesting. I don't know if anyone else is like me, but I like them with a sensitivity knob that when dimed, mashes the signal, but when relieved exposes playing dynamics. That said, I'm no expert on how they work and I've only used two, the q-tron, and the Boss AW-3. The AW-3 survived and is still on my board.
The Flat Earth is a different circuit from the Woodshed. I don't think they did a great job on the envelope follower, as it tends to breath as it releases. I suspect that they didn't use a full wave bridge. That and I think the attack control deserves a bit more than just a simple switch. As I mentioned before, the threshold didn't do much for guitar, so we left it off. So, - it's a different circuit, and it has artifacts that the Flat Earth does not have.How does the Flat Earth's "(unique, unlike ALL other compressors out there)" (feed forward design) Compare to the Suhr Woodshed Compressor (released three years ago, feed forward design)?Just curious![]()
Thank you !The Flat Earth is a different circuit from the Woodshed. I don't think they did a great job on the envelope follower, as it tends to breath as it releases. I suspect that they didn't use a full wave bridge. That and I think the attack control deserves a bit more than just a simple switch. As I mentioned before, the threshold didn't do much for guitar, so we left it off. So, - it's a different circuit, and it has artifacts that the Flat Earth does not have.
Let me know if you have more questions.
Groovy baby.Thank you !
Groovy baby.
Captain Beefheart Trips! but ... that might get be sued...How bout "Captain Trips"?
"Captain Trips" is from Stephen Kings the StandCaptain Beefheart Trips! but ... that might get be sued...
