Hey gang, looking for some advice on "what to do next and how to do it".
Neck:
Pro Conversion (Tele) / 10 - 16" compound radius / Mahogany back / Roasted Maple fretboard / S6105 frets / Earvana GraphTech nut. / relief .009" / Frets nicely crowned and polished.
Have a little more string buzz than I'd like (across all strings.. it's very uniform) and the action could be lower (currently 5 - 6/64").
Wanna be like you guys with compound radius necks at 3 - 4/64" action and NO buzz. :glasses10:
I've searched and researched my buzz issue and have come to the conclusion I'm moving my frets towards a flat state.
Probably a result of the filing technique I've used. The buzz isn't that bad. Can't hear it through the amp.
Certainly can hear it in the air and leaves me with the sense that sustain is being compromised.
So I need/want to reintroduce a smidgeon of radius back into the fret profile.
I have a set of radius gauges (7.25" - 20") and these two fret files.
http://www.stewmac.com/Luthier_Tools/Tools_by_Job/Fretting/Fret_Fingerboard_Leveling_Files.html
http://neckcheckguitar.com/fret-leveling-borard/
I understand the general consensus is that radius sanding blocks for fret work are considered bad. But they are an option I'm considering.
AND
If I had used better technique with the files, this wouldn't be a problem.
If I were to use the files to do this, what would be a good technique?
Thanks!
			Neck:
AND
Thanks!
		 ccasion14:
ccasion14:
