Now in Hodgkins, IL. on 10/23
Also, I bought some O-rings to use as washers for the input hole, which will hold the miniswitch. 3/8 diameter, 1/4 inner hole, 1/16 tube size. So two of these over the miniswitch will fill up the gap in the input hole which is 3/8's, the pickguard is .1 inches, and then I'll put the switch plate on top of the hole along with the dress nut then underneath the pickguard use a thin metal washer.
Will arrive on Wednesday! October 25.
So that's about 100 days from the time of the order.
Interesting ...
Took 50 days to plan,
Took 100 days to gather parts
I wonder how many days it will take to assemble. I'm guessing 25 days, or less. Life gets in the way. Then upto 25days for the tech to solder.
200 days in all.
Then probably three months of futzing to get it set up the way I like it.
Basically, almost 1 year. Interesting.
