Progress. Put on the tuning buttons, then attached the tuners.
Next made sure the neck was flat. Used a straight metal ruler and a magnifying glass. When I could see no light across all frets tops, I knew it was flat. Found no frets that were too high or low. This time took, less than 15 minutes.
Before attaching the neck and body together I wanted to get the pup routs set up, so I got this high tech tool called an emery board and sanded. Got the neck rout done. I think on the other pup holes I'll wrap a piece of sand paper around the emery board. Use 120 Grit.
The reason I'm expanding the pup routs is that while north to south the dimarzio minihum is the same as the gibson, east to west it's about 1/16 wider, so it needs to be widen by about 1/32, plus a skootch more on either side. If you go at it gently, doesn't seem to be a problem.
I had to ream out a little paint that fell into the tuner holes. You can see my high tech reaming tool (screw driver with sandpaper).
That 1/4 sawn headstock looks great! I love the flakes in the wood.
![20231130_224656.jpg 20231130_224656.jpg](https://unofficialwarmoth.com/data/attachments/19/19406-7e19269406dbcfb736a55fad9f7546ae.jpg)
![20231202_225928.jpg 20231202_225928.jpg](https://unofficialwarmoth.com/data/attachments/19/19407-67c0bc3355cc651ec9ea62319e7ce5b1.jpg)
![20231203_200059.jpg 20231203_200059.jpg](https://unofficialwarmoth.com/data/attachments/19/19408-cbaab0a26e68e466b9427650207d8cc3.jpg)
