Fat Pete
One proper f@*&-up, but some progress too...
Full disclosure and all that - this was supposed to have filtertrons (actually UK-wound 'Fletch-o-trons') mounted La Cabronita-style, but due to some (oxy)moronically careless over-cautiousness with the router, I'll be making some trim/goof rings - probably from thin aluminium.
On the plus side, I do now have a body with routes for the pickups, the bridge mounting screw holes drilled and the necessary holes for all the wires. I even had a go with the Shinto rasp my brother gave me for Christmas to gently contour the heel.
As you can see, I've done the counter-boring for the neck screw washers and drilled the mounting holes in the neck itself - which has also received a little Shinto-ing to smooth the square shoulders at the heel. Everything lined up nicely when I did a test fit, so I thought I might as well just get on with it for a change. I still have more sanding to do (does it ever end?) Then it's on to finishing.
The body weighs in at a stately 2 lb 13 ozs / 1.28 Kg. Fully loaded, the whole thing's going to be about 5 1/2 lbs / 2.5 Kg.
Getting back to finishing, anybody have an opinion on whether to stain the back or not, and if so, what colour? I had been thinking of just a little amber or brown so it's not such a stark contrast, but then more or less decided to just leave it natural. A friend was trying to persuade me to stain it orange as some sort of nod to Gretsch.
