teleme01 said:
1st let me say I am not a professional builder, just a shmuck :binkybaby: with wild ideas, and there are so many options. I wanted a thinline tele, so i ordered the rear routed walnut thinline with p90 routes, 510 tremolo and strat controls. now i wait the 3 months.
I had contemplated routing paranormal for jazzmasters which warmoth said could be done, then i learned of Fralins noise canceling alnico p90 which was a route offered in the builder. I have a 335 build with 2 pearly gates, I like it but wanted something different.
Ideally i would like to find a US wiring guru (920d) who will custom wire a PP-strat pickguard and not force me to buy off the shelf. basically a varitone with caps to match the p90 pickups and not a varitone built for a gibson 345. i dont need 6 different settings, maybe 2 or 3 and bypass.
i want i want i want. ... but will probably end up settling for something less.
Ok so we now need to look at what is possible with the already defined choices.
What we know so far ---
Rear routed walnut thinline with p90 routes, 510 tremolo and strat controls and time is on your side.
Can you confirm it is P90 x P90 rout or is there also a middle pickup rout?
Either way regardless of the pickups - we could be looking at a selector switch, master volume, master tone and a varitone. A Creamery Pickups P90 size humbucker in the bridge position may also be an idea to get more of a PAF tone.
We need to zero in on what is possible to achieve based on what we know to be certain and what is logically and actually possible.
Oh and don't buy something prewired for a pickguard as you have a rear rout which would need different lengths of pot shafts and when you take something off a prewired pickguard to get the pickups wires through to the cavity you would end up having to de-solder etc.
