ragamuffin said:Yeah I doubt that you're going to find a pre-made for that, but you might be able to combine a V-T-Blend strat diagram and combine it with an esquire switching scheme.
perhaps a blender isnt what i am looking for, i am looking to go from A gradually all the way to B, i am thinking there would be less noise and more control of blend. and no , unfortunately never get to play live.TBurst Std said:Don’t know if you play live, but using a blender pot as a pup selector can be painful on the fly so to say. It can be used live to make minor adjustments, but is not practical for true pickup changes.
stratamania said:It seems two things are being conflated here.
An Esquire varitone is used on a guitar with one pickup and the switch is used to switch between different cap values hence the term varitone.
A blend pot is usually used for example on a three pickup strat, with volume, tone and blender pot. The pickups connect to a selector switch as does the blend pot which then allows you to for example blend in a certain amount of bridge pickup when in neck position or vice versa. But the selector is still needed for pickup connectivity and normal selection.
So now if you have two P90s & a Tele pickup with 1 volume 1 tone 1 blender you will need the selector switch for selection and blend so there is nowhere on the switch to dedicate to varitone.
Perhaps consider using a switch to get the pickup selections you are looking for such as a super switch or Freeway and having master volume and tone and then use the other space instead of for tone or blender for a rotary switch that can switch in different cap values to the tone pot if that is something that you need.
teleme01 said:thank for your love tburst,,, in all sincerity. What my plan is is to have a neck p90 with jazzmaster tone and bridge p90 with pearly gates tone. with the varitone, i want to have maybe 3 different resistor values. as you said, only 2 of the settings were what you like, but that is twice as many as you would of had... i know i will mostly use 1 position but would like to dial in the one i like...
I am leaning toward Fralin and i know they would know which resistors would work best with their pickups, however i dont think they will custom make me a loaded pickguard with what i want, really would like to get a prewired pickguard.
teleme01 said:HUM-CANCELLING P90 WITH ALNICO RODS are Fralin P90 with Jazzmaster jangle... Porter has something similar called A90s
I dont know which p90 will get me close to a pearly gate tone...
ragamuffin said:It kind of begs the question though; why build a custom guitar with p90 routes if you're looking for jazzmaster and humbucker tones?
