Got some more work done.
As you might now, the neck pocket on the Jaguar is slightly angled:
But the bridge - since it’s a non standard bridge - still sits as low as it can get, with no room to adjust it lower.
That means that with the pickguard in place some adjustments will be necessary.
But first some holes need to be drilled for the pickguard screws. Here’s my new small hand drill that’s very handy ( :icon_jokercolor: ) for this:
Neat holes drilled:
The thumb screw holes needed to be enlarged:
But even with the holes enlarged and the thumb screws (shouldn’t that be nuts by the way?) screwed all the way down, the bridge now sits higher than before because it now rests on the pickguard instead:
The solution? Bring out the file and have at it:
Next, the pickup selector plate went in place. You might notice that the plate is thinner than the pickguard. We can’t have that:
Some washers underneath the plate fixed that:
And the end result looks much better:
With the pickguard in place I was able to do another test fit of parts. This is what I’ve got so far:
There’s still more to do, but that’s it for today.
