Max said:Yeah, I think my problem was that I used a bit that was the same size as the shaft minus thread.
I haven't put a screw bit in my drill yet for this exact reason. I hope I don't get snowed in today. I've got an appointment wednesday with the guy doing the fretwork.OzziePete said:Max said:Yeah, I think my problem was that I used a bit that was the same size as the shaft minus thread.
Too tight a shaft and as the length of the screw went in, the tension on the screw increased to a point where it stayed put within the shaft, leaving the exposed end breaking off? That makes sense. Did you use a power tool to screw it in or hand held screw driver?
Death by Uberschall said:No pick guard required, just paint it up.ccasion14:
You are correct, it's already painted. :icon_jokercolor:OzziePete said:Death by Uberschall said:No pick guard required, just paint it up.ccasion14:
I thought it was already painted up? A TV white sort of transparent finish by Tonar? :icon_scratch:
Max said:Rasp seems to be the way to go. I'm going to remove less than 1/8" total.B3Guy said:there's one thing I've learned in my woodworking experiences:Max said:That's the plan, Pete! It will be under a pickup ring, so I will need to be careful.
if you're nervous, go old-school and leave the power tools behind. it may take more time, but using a file/rasp will keep you from removing too much too quickly with a dremel.
Max said:That thing on the table was a pickguard mockup. The actual one should be done this week if I order some quick shipping.
Max said:Here it is with my pickguard test, lousily photoshopped. I'm starting to be more confident I'll like it.
Watershed said:Max said:Here it is with my pickguard test, lousily photoshopped. I'm starting to be more confident I'll like it.
Lookin good.
I like that finish.
Is that black grainfill and a semi-opaque white?
Perhaps there is a thread on it out there.
