SHall08
I’m submitting my Butterscotch Blonde Telecaster “Yellah”.
Specifications:
-Body: Swamp Ash
-String Retainer: Nickel Vintage-Style
-Neck: Birdseye Maple Neck and Fretboard
-Tuning Machines: Kluson Deluxe 6 in-line Nickel
-Nut: 1 11/16” Graphtech White Tusq XL
-Neck Plate: Glendale “Extreme" Nickel Plated Fat No-logo
-Pickguard: Vintage style 5 Hole Custom Telecaster Style Solid White
-Bridge:
-String Ferrules: Kluson Replacement String Ferrule Set For Fender Telecaster Nickel
-Switch: CRL 5-way Lever Switch
-Switch tip: Barrel Switch Knob for Tele
-Glendale vintage Blackguard "double-cut" nickel plated bridge-plate with The "Intone Cutting Edge" Spanish Electric set of three 5/16" cold rolled steel Compensated Saddles
(5-Way Pickup Switching:
Position 1. Bridge Pickup,
Position 2. Bridge and Middle Pickup,
Position 3. Middle Pickup,
Position 4. Bridge and Neck Pickup,
Position 5. Neck Pickup
-Pickups:
Neck Pickup-
TV Jones Alnico 5 Super’Tron
Pickup with Steel Blades and
Nickel Silver Cover
(Resistance: 4.0k Ohms)
Middle Pickup-
Seymour Duncan Custom Shop
Alnico 5 single coil “Staple” style
P-90; with black Soap Bar cover;
Wound with 42 Gauge Plain
enamel Wire
(Resistance: 8.5k Ohms)
Bridge Pickup-
Lollar Alnico
3 Tele Pickup With
Flat Pole Pieces, Wound with
42 Gauge Plain Enamel Wire
(Resistance: 7.3k Ohms)
-Master Volume: CTS Solid shaft, 500k-ohm
-Master Tone: CTS Solid shaft Push/Pull DPDT, 500k-ohm
-Emerson Custom .022 Capacitor
-Emerson Custom 2017 Treble Bleed Circuit
-500k Ohm Resistor: For Tone Compensation of Bridge Pickup
-Mini-Toggle Switch, SPDT On/On:
For Gilmour Mod (Adds Neck pickup for two
additional switch settings:
Position 6. Bridge and Neck Pickups Together;
Position 7. All 3 Pickups Together)
-1.1k Ohm Resistor
-Gavitt vintage style cloth covered pushback wire
-Knobs: Callaham Early 50's Telecaster Dome
Heavy Knurled Knobs
-Control Plate: Glendale Steel Control Plate Nickel Plated
-Output Jack: Switchcraft Long Thread Output Jack with Electrosocket Jack Mount, Nickel
-Strap Buttons: Nickel
-Strings: StringJoy Broadways Custom Pure Nickel
Electric Guitar Strings
.009, .010, .012, .024w, .032, .038![IMG_0692.jpeg IMG_0692.jpeg](https://unofficialwarmoth.com/data/attachments/18/18892-c242aabc3543b526e47f45ef212ce7c2.jpg)
![IMG_0694.jpeg IMG_0694.jpeg](https://unofficialwarmoth.com/data/attachments/18/18893-4df4b426bc3077535833bf741b123af5.jpg)
![IMG_0700.jpeg IMG_0700.jpeg](https://unofficialwarmoth.com/data/attachments/18/18894-6c2e9a25abc5e6e3cc782453bfe073d1.jpg)
![IMG_0693.jpeg IMG_0693.jpeg](https://unofficialwarmoth.com/data/attachments/18/18895-8e459cd0f7262377474dade5961ee4c1.jpg)
![IMG_0687.jpeg IMG_0687.jpeg](https://unofficialwarmoth.com/data/attachments/18/18896-2402971d6923c002757d99a60cb2f5bb.jpg)
![IMG_0711.jpeg IMG_0711.jpeg](https://unofficialwarmoth.com/data/attachments/18/18897-2d3f8cb37641d556a30c66713690e7a2.jpg)
![IMG_0718.jpeg IMG_0718.jpeg](https://unofficialwarmoth.com/data/attachments/18/18898-c0da582a73ffa1f5c996b6a03ac293e8.jpg)
Specifications:
-Body: Swamp Ash
-Bridge:
-Pickups:
Neck Pickup-
Nickel Silver Cover
Middle Pickup-
enamel Wire
Bridge Pickup-
Lollar Alnico
3 Tele Pickup With
-1.1k Ohm Resistor
Heavy Knurled Knobs
