Tilt back strat necked Tele
Bloozy63
Finally got to work on my Tele project. Body is chambered roasted swamp ash with f holed wenge top routed for humbuckers. I decided to do a P90 bucker in neck position and a true bucker in the bridge. Then going master volume and two tones and a switchcraft 3 way tilted at an angle for bump control. I am liking the look of the carbon fiber ph and switch plate. Neck is tilt back strat style in roasted maple and rosewood fingerboard. Schaller tuners abalone dots and side markers. Not too fancy but should please my eye.
Welcome to the forum. I like the Wenge top on it. With that carbon fiber, you wouldn't want too fancy a neck. What you have coming will work nicely with it.
Thanks Rgand, just about completed er today. Just got to string it, cut the nut and intonate. Oh, and play 😁👍👍
That is correct TheElvis. Not gonna finish this one.  Neither the wenge or roasted maple or
roasted swamp ash require it and I like the raw organic look and tones achievable when finish is omitted 😎👌
Thanks for the reply!
Thank you all for kind replys. I really have been enjoying this new warmoth build. Its pretty simple but it plays very nice. Although I have decided to upgrade the pups already. It is currently sporting iron gear pups and I recently ordered a set of Buddha 12 pole humbuckers.
Nuthin sounds as organic and tasty as a good hand wound pup IMHO. I just couldn't feel the iron gears like I was hoping too.  :guitarplayer2:
I love your hand guitar hangers. Where can I get some? Love the guitar(s) as well, Great job!
Very cool guitar.  What made you go with the tiltback and were there any issues/challenges with it?
Tiltback just makes sense, why install hardware if ya dont need to. (string trees) Plus I like the look 😎
No issues, just works great
I haven't installed string trees in many years. They were a 10¢ fix Leo implemented back 100 years ago to compensate for poorly cut nuts when his guitar designs went into production and the line workers couldn't (or didn't have time to) cut the nuts properly. Strings would pop out of the slots from lack of tension/retention. Prior to that, old acoustics tilted back the headstock for much the same reason, although beyond poorly cut nuts they were mostly strung with catgut or eventually nylon strings, which also had very low tension on them and suffered from spurious string displacement. Proper attention to nut fabrication precludes the need for trees.
Incidentally, the pic in your avatar is hosted sideways. Whoever your host or your pic display software is maybe rotating it to display proplerly on your monitor, but when it gets to the forum it doesn't know that, so it's displaying what it's being sent. You'll have to correct the original to get it to display properly here - there's no way for the forum software to adjust that. In order for me to fix it, I'd have to host it on another server where you wouldn't have access to it anymore, which wouldn't be desirable.
