mayfly
Epic Member
Logrinn said:It looks and sounds like you’ve forgot to ground the bridge.
+1 on that. You need to run a ground wire to the bridge. That will fix it.
BTW, with 'traditional' telecaster pickups, they are grounded to the backing plate, which is attached to the bridge with screws / springs. This grounds the bridge automatically. However, with your modern pickups, I'm guessing there is no ground connection to the plate. Therefore, you need to run a ground wire to the bridge.
