Frets sticking out... or gaps between binding and frets are both common on Gibson, and other guitars
The problem has to do with the neck wood, and the way it expands or shrinks due to humidity.
Cant be helped
- CB
I will add, this is a kind of "problem" that I would fix myself - I trust my fretwork a good deal better than "sumgai" in the back of a Guitar Center. It's pretty straightforward if you think about it, it just involves the removal of a very, very
very small amount of metal while protecting the surrounding wood. Like, 97.625% of fret bozo-screwups have to do with overdoing it, not under-. Dan Erlewine covers fret dressing in his "Guitar Player Repair Guide", which is a must-have book if you have any interest is saving yourself thousands of dollars over the years.
My own personal preference for this involves varying grits of wet/dry (gray) sandpaper wrapped around a big Gibson nut blank, rather than files, but either way, if you use the stainless steel fret protectors from Stew-Mac - just hold the edge to the fret, not use the slot - you just
can't nick the fretboard. Unless you're like, dangerously spastic or something. Patience & checking as you go are the only way, 22 frets = 88 corners, and the shortcut methods of gang-filing frets are piss-poor work, IMO. If you have to do the whole length, it might take 3 or 4 hours - which is why the top repair guys in Nashville and LA and New York will charge you $200.
(And at my creaking-old age of 53, an OptiVisor or magnification of some other sort is really helpful. Mebbe you ferret-eyed younguns kin... grumble creak thud etc.)
