Second 'build'. - Graffiti Yellow HSS Stratalike
Hmm? Fascinating stuff, but it's still doesn't help with whether the 'Warmouth Graffiti Yellow' is actually the colour I want.
I'm hoping for that really 'in yer face' Ibanez colour, which I believe they might call 'neon' yellow.
It's got me wondering whether it's worth contacting Warmouth...
There's a tele body in Graffiti Yellow in the showcase right now:
Also, didn't you check the guitar finishes page before ordering?
@cuthbert you seem to have a misunderstanding of what a pastel colour is. Here is a link with some definitions and examples.
Pastel Colours
This is not relevant to the discussion however you can clearly see here that the Rosso Alfa 555 is clearly a pastel color.
In the automotive industry all colours that are not metallic or mica are by default "pastel".
In the guitar industry vibratos are often called tremolo and vice versa, because of Leo Fender. That doesn't make it right. 😅
Unlike the guitar industry, the automotive industry doesn't use a lot of transparent colours as opposed to solid colours, which could be a possible explanation for the misuse of the word pastel. :unsure:
But apart from the link you posted, which is in italian, I didn't see much evidence for your claim.
On the contrary: When I googled for "pastel coloured cars" it showed me cars in colours that look like in the link @stratamania posted, which is also the definition I know.
I mean, there are also black cars and would be very surprised if someone called them pastel... :oops:
There is no single international standard (like an ISO or IEEE spec) that rigidly defines "pastel."
However, in color theory and digital color spaces, a pastel is technically defined by specific ranges within the HSV (Hue, Saturation, Value) or HSL (Hue, Saturation, Lightness) color models.
Technically, a pastel is a Tint. This means it is a pure hue mixed with a significant amount of white.
Here is the technical breakdown of what constitutes a pastel color.
1. The HSL Specification (The Most Accurate Metric)
The HSL model is the standard way to define pastels programmatically because it separates "Lightness" from the color itself. To be technically classified as pastel, a color usually falls within these ranges:
* Hue: Any (0 degrees to 360 degrees)
* Saturation: Low to Medium (15% to 50%)
* Lightness: High (70% to 95%)
The Logic:
* If Lightness is too low (< 70%), the color becomes "muddy" or "muted" rather than pastel.
* If Saturation is too high (> 60%) while Lightness is high, the color becomes "neon" or "fluorescent."
2. The HSV/HSB Specification
In the Hue, Saturation, Value model, the definition shifts slightly but relies on the same principle of high brightness.
* Saturation: Low (0.1 to 0.4 or 10–40%)
* Value (Brightness): Very High (0.8 to 1.0 or 80–100%)
3. The RGB Mathematical Representation
In the RGB (Red, Green, Blue) space, pastels are defined by low contrast between channels and high integer values.
Mathematically, this looks like:
* High Values: All three channels (R, G, B) are closer to 255 than to 0.
* Dominance: The dominant channel determines the Hue, but the non-dominant channels must be high enough to "wash out" the intensity.
For example, a pure intense Red is (255, 0, 0).
A Pastel Red (Pink) adds high levels of Green and Blue to move closer to White: (255, 180, 180).
Summary
If you are writing a script or validating a color palette, a color is technically pastel if:
* It is NOT grayscale (Saturation > 0).
* The sum of RGB values is high (usually > 600 total).
* In HSL, the Lightness is > 0.75 and Saturation is < 0.5.
See last two posts. You are incorrect, including the automotive description.
Anyway...
Was in a local branch of a UK music store chain, yesterday morning. Got my hands on an Ibanez RG550 in exactly the colour I'm after.
It's called 'Desert Sun Yellow', apparently.
Emailed Warmouth a couple of days ago, but no news, so far. Presumably, it's a thanksgiving thing?
Anyway...
Is that the new one they just released? Evidently the original was a different shade of yellow.
Grafitti Yellow is awesome, but not Desert Sun Yellow. If you want to get as close as possible to Desert Sun Yellow I’d commission a painter to do it but if you want a really well done yellow color and one stop shop, Warmoth is a great option.
Don't know whether it's a'just released' model, but it is brand new. It didn't look like the colour on the store's website, but 'in the flesh', it's spot on.
Yeah, I'm waiting to hear back from Warmouth.
Trouble is, the UK isn't overflowing with guitar sprayers, according to Google at least.
At least one I thought of when I checked no longer does spraying.
Of course, an approach available is to get a DIY paint ready body from Warmoth, and then get thyself some cans and spray.
Sadly, that's not an option - don't have the eyesight or the facilities, anymore. The one in the OP was done by me about 30 years ago. Had the paint matched to a sample and bought probably enough to do 10+ guitars. Borrowed 'the gear' and was able to do it after hours, where I worked.
Unless Warmouth can 'accommodate my wishes', it's most likely I'll settle for the Graffiti Yellow.
Hiya,
Well, since my order should be completed in the next four weeks, thoughts turn to prepping for the big day. 😆
With me 'fretting', 'scuse the pun, a couple of weeks before Christmas I acquired an Ibanez RG550 in Desert Yellow - the shade I was hoping my body might be. This morning, got the 'old faithful' out and took a side by side photo, to see how close they were.
Wow! Miles apart. Having gotten used to seeing the Ibanez, when I pulled her out it immediately struck me that (maybe) she's actually closer to 'Graffiti Yellow', anyway?
Well, I've been over the moon with her colour for the last 30 years, so...
When ther order arrives, I'll take another comparison photo.
On my screen, the Ibby looks more like lime green. I think Graffiti Yellow is a tad brighter than the yellow strat shown...
Yeah. That's Samsung's camera for ya. In the flesh, the 'Strat' is bright yellow. The Ibanez is bright YELLOW!!! 🤣
If 'Graffiti' is a little lighter, I won't be disappointed.
If it makes any difference, this is how the camera sees them in isolation...
