S shanejw Hero Member Messages 698 Nov 17, 2008 #1 I've got a volume pot that only seems to want to operate backwards. It works fine, just opposite of what it should. Any ideas?
D dbw Master Member Messages 4,531 Nov 17, 2008 #2 You have swapped some of the wires, probably two on the pot. Pics or a drawing and I can help
mayfly Epic Member Messages 9,233 Nov 17, 2008 #3 Swap the two outside lugs. Leave the center one as is.
line6man Epic Member Messages 6,443 Nov 17, 2008 #5 I would be tempted to agree with the above, but is the taper backwards? If you flipped the 2 terminals, you might have a weird taper, unless the pot was accidentally installed backwards.
T Thomas3D Junior Member Messages 36 Jan 12, 2009 #6 if your knob is reversed (ie 0 is full volume and 10 is no volume) then do as mayfly said and swap the connections of lugs 1 and 3. http://www.beavisaudio.com/techpages/Pots/ some info on pots (aimed as diy pedal makers, but still usefull) Switching the out side lugs will reverse the taper, but never change slope of the taper.
