alexreinhold
Hi all, I am really running out of ideas. Maybe you can help.
Guitar: Warmoth Tele with a metal pickguard and H-H Black Winter Set with custom nickel silver pickup covers, wired as per Seymour Duncan's instructions (3-way blade, 500k pots). Only difference: put in a battery powered LED light that is active when cable is plugged in (via a stereo input jack).
Problem: loud shrilling hiss when the guitar's volume knob is above 8/10 at high gain and at high volume.
What I've tried so far unsuccesfully:
- re-solder everything
- re-ground pickups to cover (solder)
- re-ground bridge
- wax-pot pickup covers
- wax-pot entire pickups
- disconnect battery
- re-shield/double-shield pickguard
- raise/lower pickups
Any other ideas of how I could solve this?
- re-ground bridge
