Rick
Epic Member
500K Custom Taper Pot (High Pass Filter) for Volume | DiMarzio
Standard guitar pots limit your musical expression, only starting to deliver sound at about “3” on the dial and then never getting much louder above “7”. DiMarzio’s custom taper pot is made to solve that problem by precisely delivering the same ratio of signal-to-turn as an actual 10-position...
250K Custom Taper Pot (High Pass Filter) for Volume | DiMarzio
Standard guitar pots limit your musical expression, only starting to deliver sound at about “3” on the dial and then never getting much louder above “7”. DiMarzio’s custom taper pot is made to solve that problem, by precisely delivering the same ratio of signal-to-turn as an actual 10-position...
Treble Bleed - Gombrelli Guitars USA (Stratocaster Design)
Fender Stratocaster Treble Bleed Circuits and explainations by Gombrelli Gutars USA.
