Bruno said:I also thinked two-piece (centerline) but following image... :icon_scratch:
I don't see the join ... (it's not a chambered body)
DMRACO said:Bruno said:I also thinked two-piece (centerline) but following image... :icon_scratch:
Much of the joint is hidden by the pickup routing. You can see just a hint on the bottom That is a real nice piece. I would not at ALL concern your self with this. almost ALL guitars have two piece bodies. This one is hidden very well too
Bagman67 said:IT may be that this is a two piece back with a droptop laminate on the front - the burst edge makes it hard to tell. I've seen it with some of the more pedestrian pieces of lumber in the back, with a more interestingly figured frontside (whether ash or mahogany - never seen it with alder, but you never know). Same thing could be going on here.
Bruno said:Bagman67 said:IT may be that this is a two piece back with a droptop laminate on the front - the burst edge makes it hard to tell. I've seen it with some of the more pedestrian pieces of lumber in the back, with a more interestingly figured frontside (whether ash or mahogany - never seen it with alder, but you never know). Same thing could be going on here.
Absolutely not.
It's a solid body, not a chambered body (so not laminated-top).
I think you will find that the other laminated-top bodies are also described as solid, except when they are chambered or hollow - so the "solid" label is not necessarily an indicator of whether a lam-top is present or not.
Further investigations are required...
peace
Bagman
