stratamania
Mythical Status
Ah good more parts ordered...
I notice you mentioned using a tremel-no, you might want to take a look at my post here.
http://unofficialwarmoth.com/index.php?topic=22445.msg338072#msg338072
You will see there that I ended up not using the tremel-no on that guitar but will use it on a future build. I was going to comment on it then as what I would do next time prior to screwing in the claw is locate the screws through the claw but prior to screwing them in place a backplate across the top of the claw as a check that it will fit flush. If you look at post 69 in the thread I linked to you can see some masking tape I have used to make sure the claw I did use was correct. If you use a backplate across there when fitting the screws and claw you may be able check as you work.
