TonyFlyingSquirrel
Master Member
Eric Banjitar said:First of all, I love watching this build. What a unique guitar you will have.
My question: Are you going to sew the edges together with the hides wet, so they can stretch and tighten? Kinda like a drum head? Or...?
Thanks, just courious.
I will likely tie the hides together dry. I took some scrap and wet it to see how it would dry, and really the only thing that happened was that it dried with some slight discoloration. I consulted with Jerry Chapman (www.jerrychapmanministries.wordpresscom) who built my hand drum. Wetting the hide and stretching is part of the process of curing it. These hides for this guitar were tanned 16-18 years ago. When they're smoked, they become waterproof for the most part and any permananent stretching is usually gone as far as it will go at this point. Additionally, I would run the risk of the adhesive on the face and back of the body giving way to the water, which would cause slippage, and perhaps through the alignment around all of the components, ie; bridge, pickup, neck pocket, control cavity.
I'm gonna lace it up dry with moderate tension and allow time and playing to cause any distressing that may occur. Again, unlike the source material for this project, the Fender Custom Shop Calender model, this guitar will indeed be played, and played often rather than sitting in a museum or gallery.
I'm hoping to glue up the back & front today. I'll roll out any air on the surface to get maximum contact with the adhesive and body, let it dry a day or so to really set, & then begin the lace up.
