C
chime13
Hello All,
Just wanted to share some impressions of my new Warmoth neck.
Conversion 24 3/4” scale on a Squire Jim Root Tele body with Seymour Duncan “Whole Lotta Humbuckers”, a Fender Superswitch. Hipshot locking tuners. Using .009-.046 Strings
Note: I was unaware that the Gotoh Truss adjustment add-on is directly beneath one of the 4 neck screw holes because of Fender’s contoured heel. I ended up using 3 bolts to hold the neck. Also had to shim the neck in order for it to be perfect. (Original neck did not need shim)
Also: noticed some slight imperfection on the center of the fretboard but it’s only visual
I love this neck! Quality and playability are a 10/10
