bagman67
Epic Member
Ahoy, mateys -
With an eye toward replicating the photo I posted the other day (black and red striped grain on ash), I went down to my local Woodcraft shop yesterday and procured some materials to do a test run, so I don't end up beta-testing my finish ideas on a final product:
A 3/4" x 4" x 48" plank of ash for making samples
Mixol universal tints in black, red, blue, and purple
Lacquer thinner to serve as medium for applying the dyes per jackthehack's blue J-bass project
Timber-mate Water-based wood filler in the charmingly-named "rustic ebony" color. That'd be "black," to anyone outside the marketing department at Timber-mate.
Deft rattle-can lacquer sanding sealer
I'll procure Deft rattle-can lacquer to topcoat all this later this week, but I won't be in a position to need it for a while in any case.
I would welcome feedback on the viability of my proposed schedule, and answers/opinions to the questions interlarded among the steps:
Starter question: What kind of gloves work best for wiping on the tint via lacquer thinner? Will latex disintegrate when exposed to toluene, etc.? Any opinions on nitrile, vinyl, etc.?
Okay, by the numbers:
1 - Sand (should I go to 180? 220? finer still?); wipe with lacquer thinner or naptha to clear sanding dust (sorry, no compressed air around here)
2 - Apply black dye - wet surface with medium, then apply the dye mix itself
3 - allow to dry, then sand back to expose soft grain; clear the sanding dust again
4 - Apply colored dye - should I wet the entire surface again, or would that tend to make the black dye bleed into the exposed grain? I suppose if my colored dye is suspended in the same medium, if there's any danger of bleeding it won't be eliminated by not wetting. Maybe I'm answering my own question here...
5 - once second color has dried, apply lacquer sealer - how many coats, how heavy-handed should I go here, how long between coats?
6 - apply grain filler according to product package instructions; repeat as necessary to get maximum fill and surface smoothness
7 - wipe once more to clear of sanding dust
8 - Begin applying lacquer coats
Thanks in advance, and retrospectively to all who have generously supplied helpful information and encouragement so far. And obviously there are numerous sub-steps to many of these, including the ever-popular "Swear profusely, then fix whatever it was you screwed up."
Best regards,
bagman
Best regards,
bagman
