Hey Byron, sounds good. Thanks for sharing. Applying 1000 grit at the end of the process is alluring.I've used TO on a mahogany neck and over poly on a maple neck, plus a few bodies. TO feels a lot different than poly. 320 should be fine. First coat I put on and let it soak in by keeping it wet using a cotton t shirt. wipe smooth and let it cure over night I was able to do two thin coats a day after that, thinning the last coats with mineral spirts. Beware if the oil starts to get tacky when you apply it, leave it alone or you will get drag marks. Put it on thin and fast, wipe it smooth and go for coffee. Thin coats are easier to apply and dry/cure better. Try not to sand. if you cut through the top coat it will show under the next coat. I think 0000 is too coarse to finish. I stripped the TO off a neck with 0000 to correct my mistakesI have used 1000 grit to make gloss poly satin. Truoil is a film finish(varnish) not oil
Lots of different methods and ways of applying it. Any day now the materials come in the mail and I must make a choice and stick to it. All of these posts helped me make an informed choice. Thank you.
Any other methods or discussions are welcome.
