VIP Setup Challenge...Bridge Very High
I'm embarrassed to admit how many HOURS I've spent so far...but I'm making progress!
Thanks to everyone here I've been able to get my guitar close to dialed in. I still need to set pickup height, and I've decided to replace all the elctronics. I currently have a decent harness, which includes to push pulls for coil splits. However, I don't like the feel of the pots, Bournes which feel too loose, and have decided I'm not a push pull guy. Instead I'm going to wire up a set of Triple Shots and switch to CTS pots and 50's style wiring.
Here's my progress so far.
Relief: Using the notched straight edge as a guide and feeler gauges for measurements I was able to set the relief to .005". It took several minute truss rod tweaks and a whole lot of patience, but I got there.
Action: After getting the neck adjusted I was able to adjust the string height down to a buzz free 1/64" on the treble side, and 2/64" on the bass.
Nut: After measuring the nut it was apparent it was cut too low. I couldn't balance the relief and action the way I wanted. As such, I've ordered a new Graph Tech nut and will get that installed asap. The old one is plastic so it was time to go anyway. In the meantime, I shimmed the nut with a thin slice of business card. It's a bit high, but pretty darn close and zero buzz which is nice.
Other: Thank god for real tools! No way I could get this dialed by eye. I knew something was wrong with the original setup, but no idea how to fix it. Also, I've decided to replace the tuners. If I put in this much work to get the setup right, I might as well make sure tuning is as good at it can be.
A few quick pics:
Original:
Adjusted:
A bit more relief on the treble side, but darn near .005" across the neck.
1/64th on the treble side...pic turned out blurry...
Original bass string action:
Adjusted:
May not look like much, but I've been able to drop the bridge by about 1.5 turns
Original:
Adjusted: I have not adjusted pickup height yet
Original:
Adjusted:
Original:
Adjusted: Bad pic...
My new best friends:
