Verne Bunsen
Cagey said:-VB- said:This from Warmoth:
"Hi Vann,
We use the Green 3M tape. It’s a lower tack so it doesn’t stick as hard but gets the same job done. We’ve seen the blue tape cause this a few times. It might react differently for house paint but we’ve found that it can stick too much for our products."
Looking into it there are a couple of varieties of 3M green tape: 2060 which is a high-adhesion "hard-to-stick surfaces" (advertises brick, concrete, stucco) tape which does say it is safe on lacquer, and 401+ which uses a solvent-free rubber adhesive and boasts high temp resistance for automotive applications. So, clear as mud...
I have a roll of that green stuff here, but I rarely use it because it's too aggressive. I mean, it's wicked sticky. Warmoth has taken to using it to secure the styrofoam wrapping on necks/bodies, and there's no peeling it off; you have to cut it.
To be fair, as you pointed out, 3M has a wide variety of products that look the same, but aren't. So, you can't just say "use the [insert color here] tape". You have to know which product is the one that's designated for use in helicopter airlifts vs. teasing your cat.
Yeah, I'm not sure what to make of it right now. I've used that same blue tape on every body and neck I've worked on with nary an incident (well, except for this one...) so I'm inclined to say there isn't a problem there. But, having said that, I don't ever ever ever (ever ever ever, ever ever) want to ever remove tape and see that nightmare looking back at me ever again so what's a feller to do? I guess I'll wait till the verdict is in on their inspection before I go getting too neurotic about it...
