PhilHill
Cagey said:PhilHill said:Thank You and yes. It's just plastic binding (probably ABS), I used a piloted router bit that put a 1/4 rabbit in the edge and glued the binding in with CA adhesive. With the plastic binding you can get away with sanding it some without it melting.
Interesting. That looks like a carved-top body? Must've been a bit of a trick to get the edge routed for the binding. I did the 5-layer binding on the L5S in my sig, which has a flat top, and that was nerve-wracking enough. Build thread's here, if you're interested. I found scraping the binding was more effective than trying to sand it level. Still have to sand it eventually, but the scraper works well to start with.
The final part of the carving was done after the binding route was cut, but yes it still was great fun. Had to use additional support blocks around the treble side horn. And your right about doing most of the leveling with a scraper. In fact I had to buy a new box of single edge blades before I could do it, didn't realize I was out till I needed one. But, all told it was better than it used to be with the old celluloid binding. That stuff would go bad if you looked at it wrong.
