Paul_in_KC
So, I guess this is sort of a continuation of my first post in "Out of the Box"
Here are a few pics of my Telecaster build.
First, a finished picture of the neck. It's a new USA Fender American Standard neck. I replaced the standard white plastic markers with abalone that I selected to complement the body finish. It turned out great. I am really happy with the result. I think it looks great on the guitar too.
Since this neck has the Micro-tilt feature - I decided to install the parts in the body for that to be functional...
Here is the neck on the body before I started working on the body...
Shielding the cavities - first with paint and then with copper. I was just going to use the paint - but someone said they had some trouble with the shielding paint flaking and causing problems in the electrical components. So, I decided to line the paint with copper. The cooper will keep the paint from flaking if it was going to - and is a lot more conductive than the paint.
Here is the body with the bridge and pickups (Lindy Fralin) installed...
[I think she's a looker]
So, here comes the question. It was at this point, when I started to install the controls (going to wired with S-1 switch on volume like American Deluxe) that I realized that the S-1 switch and tone pot that I ordered are "short" thread/shaft and won't mount with the rear route as is.
I really want to use the S-1 switch - but it's not available in a long thread version (as far as I know).
It seems that other's here have simply routed more material around the mounting hole - similar to what Warmoth does around the selector switch mounting.
Anyone here with direct experience resolving this?
I considered switching to a 4-way selector and long-thread pots. But can only find those in split-shaft. And I'm not sure if the knobs that I bought to mount on solid shafts will work with the split. I hate to buy new knobs too.
Any input would be appreciated.
Thanks,
-Paul
Thanks,
-Paul
