Cagey said:Well, I'm running Firefox on Linux with several additional filters in place, so it's possible something doesn't like something about that link and so is refusing to load it. I don't see anything obvious, but sometimes it's not.
stratamania said:Cagey said:Well, I'm running Firefox on Linux with several additional filters in place, so it's possible something doesn't like something about that link and so is refusing to load it. I don't see anything obvious, but sometimes it's not.
Seems to be hosted on googleusercontent, with a URL a bazillion characters long. So that might be it.
Cagey said:Your picture doesn't show up. The link is ridiculously large - the forum software might not be able to handle it.
Agree - I started using Google Photos when PhotoBucket stopped serving images to forums without a subscription. Not the most elegant photo hosting app I'm sure. But hoping that Google will improve things. If not, I'll have to find something else.
As for clamping to the stage on the drill press, what I've done is create a larger secondary stage that attaches to the press' stage, so I have a friendlier surface to work with. Kinda like this, but mine's not quite as fancy...
With bodies, especially finished ones, you just need to put load-spreading pads under clamp heads to keep them from marring the surface.
Now that's what you need to hold a body! If I had something like that, I would have used the drill press. And if it turns out that I do more of these - then I have seen a really nice solution that I can copy. Thank you!
-Paul
Cagey said:Yes, everything shows up except the one under discussion and one at reply 12 regarding the neckplate.
Fat Pete said:The pic in question was showing ok for me but now all I see is a no entry sign.
[edit] The forum has been a bit flaky for me the last few days, so might not be all Google's fault.
Fat Pete said:The forum has been a bit flaky for me the last few days, so might not be all Google's fault.
wildbill92879 said:That is one beautiful Tele,,,,and I don't even like them. I like that one though. Nice work. Enjoy.
Verne Bunsen said:Well done! That's a fine looking Tele!
Rgand said:Man, that came out good. Very nice Tele, there. :icon_thumright:
stratamania said:A good result.
For photos I moved from Photobucket to Flickr, others are using Imgur but I am not convinced about their T&Cs for content hosting.
Thanks Stratamania. I'm a Google Chrome user and also use their Contacts and Calendar apps - so, will give them a little time to improve the Photos app for image hosting. If they don't sort it out, I'll look at Flickr.
I see you have one of the SKB flight type cases, I have a similar one with a different interior which I think is an earlier model.
Yeah - needed a case. So, thought I'd buy something a little better than the regular "hard" shell. I'd like to have something like this for all of my guitars. However, I am somewhat disappointed in the fit of this case for either Teles or Strats. Neither guitar is properly supported in the case unless you put something under the body in the right place (like terry washcloth). Very nice case - but for that kind of money you shouldn't have to do anything to get a perfect fit. I would have returned it (to Musician's Friend) but the return shipping was prohibitively expensive. At least compared to the relatively easy "fix".
