Super Turbo Deluxe Custom
Epic Member
It can be a tricky proposition. One of the drawbacks of the onboard preamp is that it can't give the soundman a flat signal to work with. If you like the sound, and the soundman likes the sound, win win. When I do play the EBMM, I cut the treble and mid just south of the center detent and leave the bass flat. Even then, it's not truly flat because of the flavor of that preamp but it still gives the FOH guy something to boost or cut. Anything else I'd do for stage EQ is on the amp which is close to flat anyway. The reason I say all that, a band I sub for, their regular guy has an HH Stingray 5, he turns the bass all the way up, cuts the mids and treble all the way off and uses both humbuckers full on, never touches anything. That's his one sound. He complains he can never hear anything and FOH guy has nothing to work with. He (FOH guy) can't boost the mids or treble because they never got to him. Whereas all passive, send pre EQ flat signal to sound guy, let your amp make your ears happy and trust the soundman makes you sound good.
