Here we go again! I own both an Orange AD-30, and a Line 6 Pod, so I decided to see if you can tell the difference as to which is t00b and which isn't!
The Pod Rig consists of: My Warmoth thinline> Pod (Citrus Model, "4x12 British V30's" cab, "57 on axis" micing, and 0% room.)
The Orange Rig: thinline> Orange AD-30 HTC head> Orange 2x12 cab loaded with V30's> Audix OM 2 mic, miced on axis to one of the speakers.
On both the pod and the amp- gain and eq set the same. "Presence" on the pod was set at 12 o'clock as the amp has no presence control.
So the discrepancies are, the cab size and mic- as far as cab size goes, when only one speaker is mic'd, I find that it makes very little difference. I am sorry about my mic choice, but the audix om2 is as close as I have to a 57- both have the same size diaphragm, and a similar design.
To record these clips, I DI'd my guitar, then played that signal back into the two rigs.
This one might be a little more challenging than the AC 30 debate, cause the AD 30 isn't quite as well known of an amp!
Good Luck Super Lizard!
The poll ends in 2 days.
